nRF52832 Tracing & Soft resets
    • nRF52832 Tracing & Soft resets
      I'm collecting trace data using J-Trace and Ozone. It is meant for Code Coverage purposes and our test procedures involve several Soft Resets. After a Soft Reset the orange TRACE LED on J-Trace is active, however Ozone stops receiving trace data. Is there a ways for Ozone to keep collecting data after a Soft Reset ?
      Arm tracing was not designed to survive resets. So the answer is no.
      What you could try is to halt the debug session after reset and resume it in Ozone. That might work. But any data before that point would be gone.
    • New
      Adding a breakpoint at the beginning of main() does the job. After a reset execution stops at the breakpoint and, after resuming execution trace data is being collected.
      Is there a way to script this operation? Detect a halt on a breakpoint and call Debug.Continue() automatically ?
    • New
      Yes you can automate Ozones GUI actions.
      Here is an example where an action is executed after e.g. a breakpoint is hit:
      wiki.segger.com/Automated_Tests_with_Ozone#Debug_example
      So you could set a breakpoint before or after main (on main will maybe not work as the debugger clears the breakpoint of the application entry point automatically so you save one hardware breakpoint) and execute the debug contione action which would trigger the whole trace init again.
