[SOLVED] Failed to read back target memory (LPC55S69) with J-Flash V7.66b
  • [SOLVED] Failed to read back target memory (LPC55S69) with J-Flash V7.66b
    When I try to read my LPC55S69 flash memory with JFlash V7.66b and a J-Link I receive the following error: 'Failed to read back target memory'. Nevertheless, there's no problem when I use J-Mem V7.66b and the same J-Link. This is what the log file says:
    Connecting ...
    - Connecting via USB to probe/ programmer device 0
    - Probe/ Programmer firmware: J-Link V9 compiled May 7 2021 16:26:12
    - Device "LPC55S69_M33_0" selected.
    - ConfigTargetSettings() start
    - Disabling flash programming optimizations: Compare, SkipBlankDataOnProg
    - ConfigTargetSettings() end
    - InitTarget() start
    - InitTarget() end
    - Found SW-DP with ID 0x6BA02477
    - DPIDR: 0x6BA02477
    - CoreSight SoC-400 or earlier
    - Scanning AP map to find all available APs
    - AP[3]: Stopped AP scan as end of AP map has been reached
    - AP[0]: AHB-AP (IDR: 0x84770001)
    - AP[1]: AHB-AP (IDR: 0x84770001)
    - AP[2]: JTAG-AP (IDR: 0x002A0000)
    - Iterating through AP map to find AHB-AP to use
    - AP[0]: Core found
    - AP[0]: AHB-AP ROM base: 0xE00FE000
    - CPUID register: 0x410FD213. Implementer code: 0x41 (ARM)
    - Feature set: Mainline
    - Found Cortex-M33 r0p3, Little endian.
    - FPUnit: 8 code (BP) slots and 0 literal slots
    - Security extension: implemented
    - Secure debug: enabled
    - CoreSight components:
    - ROMTbl[0] @ E00FE000
    - [0][0]: E00FF000 CID B105100D PID 000BB4C9 ROM Table
    - ROMTbl[1] @ E00FF000
    - [1][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
    - [1][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
    - [1][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
    - [1][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
    - [0][1]: E0040000 CID B105900D PID 000BBD21 DEVARCH 00000000 DEVTYPE 11 Cortex-M33
    - SetupTarget() start
    - SetupTarget() end
    - Target interface speed: 2000 kHz (Auto)
    - VTarget = 3.329V
    - InitTarget() end
    - DPIDR: 0x6BA02477
    - AP map detection skipped. Manually configured AP map found.
    - AP[0]: AHB-AP (IDR: Not set)
    - AP[0]: Core found
    - SetupTarget() end
    - Executing init sequence ...
    - Executing Reset (0, 0 ms)
    - ResetTarget() start
    - Reset strategy selected in debugger ignored. Performing device specific reset.
    - Reset handler addr: 0x00003974
    - ResetTarget() end
    - AfterResetTarget() start
    - AfterResetTarget() end
    - Initialized successfully
    - Found 1 JTAG device. Core ID: 0x6BA02477 (None)
    - Connected successfully
    Reading target memory (0x00000000 - 0x0009DDFF) ...
    - Start of preparing flash programming
    - End of preparing flash programming
    - ERROR: Failed to read memory (0x20000 bytes @ address 0x00000000)
    - Start of restoring
    - End of restoring
    - ERROR: Failed to read back target memory
    Disconnecting ...
    - Disconnected
    Reading erased ECC flash will result in an ECC error and in a memory read to fail.For most ECC flashes (including this one), reading programmed areas is allowed only and
    reading erased flash is expected to fail.
    I assume that this is what happens in your case (you can check this by verifying the ECC error flag of the flash controller).
    Solution:
    Either you disable ECC or you do not read erased sections of the flash.
