[SOLVED] J-Flash Target Device Setting
  • [SOLVED] J-Flash Target Device Setting
    I'm trying to program a hex file to Infineon CY8C6136 using Segger J-flash (V7.66a).
    Q1. Which one should I choose from the list in the Target Device Settings?
    I attached file.
    Q2. What is the difference between CY8C6xx6_CM4 and CY8C6xx6_CM4_sect256KB?
    Thanks and Regards,
    YS
    This is a MCU from the Infineon / Cypress PSoC-6 series. Support for these chips was added by Cypress, we are just shipping the connect scripts and flash loaders they provided.
    For support, you need to get in touch with Infineon.
