[ABANDONED] S32K144 RAMCode Failed Question
  • [ABANDONED] S32K144 RAMCode Failed Question
    Hello
    While using S32K144, the same error as in the picture occurs.
    What should I do?
    Jlink log file is also attached.
    • JLinkARM.log
      (12.17 kB, downloaded 119 times, last: )
    • JFlash.log
      (3.09 kB, downloaded 96 times, last: )
    Such errors often point to connection / setup issues.
    It looks like J-Link either cannot write the RAM @ 0x1FFF8000 *or* the RAM is written correctly but reading brings garbage data.
    Some things to check:
    • Does it get better with slower interface speeds (you are currently using 4000 kHz, what about 1000 kHz)?
    • Do you use short cables between J-Link and target MCU (< 1m, ideally not above 30cm)?
    • Are there any other things between J-Link and the MCU? (isolators, relays, ...) => Does the problem go away with eliminating the things in between?
