[ABANDONED] JScope fails on start
  • [ABANDONED] JScope fails on start
    Using JScope v7.64c and JLink-Ultra+, I am trying to capture some data from my Apollo3 target. The target is set up and SystemView works well with it, however, when I request JSCope to start recording data I get an error "Could not start data reading: Unspecified error."
    Also, I have noted that the configuration is not restored when I save and load the project. This means having to set the options each time I start JScope. In fact, the options are not even saved when the options dialog is closed and then re-opened.
    I really need to use this tool so any help would be much appreciated.
    there was an issue with the options dialog introduced with J-Scope V7.64c. It has been resolved with V7.64d. Would you download the new version and check if it resolves the issue you are seeing?
    Matthias
