[SOLVED] SystemView via Command Line : How To?
  • [SOLVED] SystemView via Command Line : How To?
    I didn't see any threads on this issue.
    The User's Guide indicates that "SystemView can be controlled and configured via command line options" but doesn't provide any examples of how to do so.
    On both MacOS and Windows, trying to use SystemView from the command line just seems to continuously generate errors.
    Does anyone have any working examples of how to use SystemView from the command line?
    Thank you!
    How the command line works in SystemView can be found in the SystemView manual in chapter 3.11.
    There you can also find examples.
