[ABANDONED] Howto Set JLink CortexM reset strategy and Delay using Ozone
  • [ABANDONED] Howto Set JLink CortexM reset strategy and Delay using Ozone
    Trying to use Ozone on a Microchip ATSAMG55J19 - CortexM4 target. The standard reset strategy does not work on the target. So, I'd like to direct Ozone to tell Jlink to use Reset Strategy 2 and add a 100 ms delay to the Jlink reset sequence.
    The Jlink Commander commands for these settings are 'rst 2' and 'rx 100' (instead of just 'r').
    What approach should I follow to change the target reset behavior under Ozone? I've looked at some of the scripting available in Ozone, but the objects being manipulated don't seem to map to JLink commander commands.
    Dale
  • Hello Dale,
    To best of our knowledge the default reset implemented for the device is working as expected.
    Why do you think it is not working? How do you come to that conclusion?
    Generally to edit the reset behaviour in all our tools we recommend to use a JLinkScript as they are portable between all tools that support J-Link:
    wiki.segger.com/J-Link_script_files
  • Hi Nino,
    Sorry for the extended delay in responding.
    Essentially, when I switch to reset strategy 2, I expect to see the Jlink toggle Reset# low. However, when I issue rx 100, the Reset# line does not toggle low. I can make it go low using JlineExe by issuing 'r0' and release it by executing 'r1', which means the Jlink itself is working fine.
    I am trying to learn enough to create a JlinkScript that can be used in Ozone to reset this CPU (ATSAMG55J19) properly. FOr some reason, the default reset strategy does not work using Ozone nor JLinkExe.
    Thanks!
    Dale
