[ABANDONED] How can I manipulate a global variable in Ozone.
  • [ABANDONED] How can I manipulate a global variable in Ozone.
    I am very new with Ozone and I cannot change the value of a global variable to see the programm's reaction after the manipulation of the value.
    I tried with an expression but when I step in assembly code and the variable has been loading in the register, the register has the default value, in my case 0.
    I use Ozone V3.26 and J-link OB.
    When I try with STM32Cube IDE embedded Debugger, then I can manipulate the global variable. Can you help me because it looks very strange.
  • Hi, I have found with try and error the problem. Now I am thinking that is a bug from ozone.
    The variable qSoll is type of float and if I enter in Watched Data window in value field the '1' then in the uC memory field will be not updated, the memory still contains the value 0 but in the Watched Data window will be shown the value '1'.
    If I enter in Watched Data Window the value '1.01' then everything is working properly.
    What do u think? Is it a bug?
    The post was edited 1 time, last by ntosis ().
    Do you see the same issue with the latest Ozone V3.26c?
    If yes, is your application build with code optimization on?
    Could you disable code optimization in Cube IDE, rebuild the application and try again?
