[SOLVED] Improving SystemView resolution
  • [SOLVED] Improving SystemView resolution
    I'm using SystemView in order to get some insights on critical timing sections in my program and the resolution.
    SystemView is initialised with a resolution of only 32.768KHz, while the cpu clock is 64MHz. So I can see events changing every 30.5[usec], which is not enough (see screenshot).
    I'm using the nrf52840 with Zephyr as file system.
    Can this resolution be improved?
    [/quote]
    Typically we recommend using the Cyclecounter of the MCU for the timestamps to get a resolution based on your CPU clock. But on some target devices the Cyclecounter is not available and some other timer/clock is used for reference, e.g. the RTC here.
    For more information about how to implement an alternative timestamp source see the SystemView documentation under SEGGER_SYSVIEW_GET_TIMESTAMP() and the referenced samples there.
