[SOLVED] J-Scope 7.62a broken functionality
  • [SOLVED] J-Scope 7.62a broken functionality
    Is it just me or does J-Scope 7.62a have broken functionality that makes it very difficult to use? Here's a list of what I've run across.
    1) float types are sometimes incorrectly labeled as uints. It's very inconsistent and I can't figure it out. The same variable can sometimes show up as a float, othertimes as a uint.
    2) enums cannot be selected, even through they're labeled as uchar in J-Scope.
    3) booleans can be selected, but they don't get any data.
    4) No smooth resizing between the graph and variable windows. If the overall j-scope window is below a certain size, it's either 90% graph, with only 2 variables visible in the variable window, or it's 100% variable window. It cannot be arbitrarily sized.
    There's probably a few other things that I'm missing. Is there any work being done on improving J-Scope? It's a handy tool to use and it would be nice not to have to keep using a separate installation of J-Scope 6.
    thank you for bringing this to our attention.
    Would it be possible for you to share an .elf file that can be used as a reproducer to demonstrate these issues?
    Matthias
    I have sent you a private message for sharing the .elf file.
    Matthias
  • Another issue that I found this morning is that exporting to a CSV file will not export all of the variables if more than 5 are being watched. I'm not sure which one is not being exported, but I think it's the first variable that is not exported if there's more than 5.
    we are not aware of any issue like this. Could you please create a ticket about this issue with our support ticket system?
    support.segger.com/
    It makes keeping track of different issues a lot easier.
    Matthias
