Appwizard export will change the encoding of my code
    • Appwizard export will change the encoding of my code
      Hi
      The code before export is as follows.
      1. void ID_SCREEN_LEARN__ID_SWITCH_MODE1__WM_NOTIFICATION_VALUE_CHANGED_0(APPW_ACTION_ITEM * pAction, WM_HWIN hScreen, WM_MESSAGE * pMsg, int * pResult) {
      2. GUI_USE_PARA(pAction);
      3. GUI_USE_PARA(hScreen);
      4. GUI_USE_PARA(pMsg);
      5. GUI_USE_PARA(pResult);
      6. int siwtchState = SWITCH_GetState(WM_GetDialogItem(WM_HBKWIN, ID_SWITCH_MODE1));
      7. printf("switch 1 toggle val:%d\n", siwtchState);
      8. if (siwtchState)
      9. { //learn mode
      10. TEXT_SetText(WM_GetDialogItem(WM_HBKWIN, ID_TEXT_WORKMODE1), "学习模式");
      11. } else { //work mode
      12. TEXT_SetText(WM_GetDialogItem(WM_HBKWIN, ID_TEXT_WORKMODE1), "工作模式");
      13. }
      14. }
      The code after export is as follows
      8. if (siwtchState)
      9. { //learn mode
      10. TEXT_SetText(WM_GetDialogItem(WM_HBKWIN, ID_TEXT_WORKMODE1), "?-|?1??��????");
      12. TEXT_SetText(WM_GetDialogItem(WM_HBKWIN, ID_TEXT_WORKMODE1), "?????????????�꨺?");
      13. }
      14. }
      My file encoding is utf8.How to solve this problem.
      Thanks!
      You need to convert the strings to UTF-8. To do this, I recommend using our tool U2C.
      Alternatively, you can use this website to convert the strings: browserling.com/tools/utf8-encode (third-party website not affiliated with SEGGER).
      You can find more detailed information about UTF-8 encoding in our manual: segger.com/doc/UM03001_emWin.html#UTF_8_encoding
      Florian
