[SOLVED] Environment Option->Language
  • [SOLVED] Environment Option->Language
    Hi,I'm a new user to Embedded Studio and I have some questions about the settings of Environment Option->Language.
    I have changed every options on the picture but I can't find any difference when I coding after I changed those option.
    Do you have some examples of those options to help me understand those functions on the picture better?
    Thank you very much. :thumbup:
    Could you elaborate what is not clear with the options?
    The option names should be self explanatory.
    If you need more info what which option does select it, at the bottom will be a short description.
    Examples are not available.
