We use the ATE system in our automated PCB production lines. So far, we have limited this to ARM and that ilk.
I would like to eliminate our use of the Microchip PM3 in these fixtures, and I understand that there is support for this chip in the ATE.
I have been trying to verify this using the Flasher Portable Plus. We have never used SEGGER products on the PIC chips, and I seem to be doing something wrong..
What I am Doing:
I would assume that by even entering LVP mode that the wiring between the Portable Plus and the board is correct. Especially with the 'successful' flash operation..
Thanks!
What I am Doing:
- Set up UNI (Universal Flash Loader Configurator) for the PIC18F46Q10
- Load the HEX file provided by our software team.
- Attempt to Download configuration to Flasher I get the error: Warning: Error while reading data file! Error: Aborted download to Flasher
- So I [File-> Generate Test Data File] in Uni, and it creates and loads a .MOT file
- Attempt to Download configuration to Flasher: This succeeds.
- Load PIC using Flasher Portable Plus: This takes a reasonable amount of time, and reports success.
- But the PIC is not running correctly. (At all)
- I read the chip back using Microchip IPE and ICD4
- The config bears no resemblance to the config in the .HEX file, and in fact the code protect bit is now set making comparison of the program area impossible.
- I erase the chip and load with IPE and ICD4, the same .HEX file
- The board functions properly. The read back succeeds and matches.
Thanks!
