[SOLVED] Path substitution issues for elf built in Linux Docker but debugging on Windows.
  • [SOLVED] Path substitution issues for elf built in Linux Docker but debugging on Windows.
    I've got an elf I've built using a Linux based docker container that I want to debug using Ozone on Windows.
    I've got the problem that Ozone can't resolve the file paths.
    When I try to load a file I get the following error:
    1. File.Open ("/usr/Software/micropython/lib/libc/string0.c"): File not found.
    I've tried using the following thinking that it would substitute and resolve the further path, but it doesn't seem to work:
    1. Project.AddPathSubstitute ("/usr/Software/","C:\Develop\Software\");
    I'm not seeing any error logging as to what it's trying to resolve and failing either.
    Any suggestions on how to get my Ozone project to correctly load the source files?
    See here for more information on how to make Ozone projects portable:
    wiki.segger.com/Make_Ozone_projects_portable
