[SOLVED] Load file from command line
  • [SOLVED] Load file from command line
    I am trying to load file to my XMC1400 MCU via SWD. I am using XMC Link pribe(Jlink lite) I can do it by using Jlink.exe directly. But I want to do this by windows command line.
    It seems like -loadfile is not recognized trough command line. I checked the manuals and I confirmed this. But is there another I can do this? By using other .exes or .dlls? (I must add, I'd prefer doing this without any purchases.)
    İpek
  • Hi İpek,
    Programming directly via command line is only supported via J-Flash, which requires a J-Link Plus or higher.
    Another option would be to acquire the J-Link SDK and developing an application yourself (the SDK is not free).
    However the following method might be sufficient in your case:
    wiki.segger.com/J-Link_Commander#Using_J-Link_Command_Files
