Hide or Show dinamically a Button widget
    • Hide or Show dinamically a Button widget
      Hi to all,
      I hava aWindows with 5 buttons generated with GUIBuilder (I use version from ST, so GUIBuilder mandatory).
      I need to dinamically apdate caption e number of Buttons (hide or show some buttons).
      For caption, I modified the _aDialogCreate to retrive Data from a array that I fill before call CreateWindow()
      1. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
      2. { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 240, 320, 0, 0x0, 0 },
      3. //{ BUTTON_CreateIndirect, "1", ID_BUTTON_0, 45, 7, 150, 50, 0, 0x0, 0 },
      4. //{ BUTTON_CreateIndirect, "2", ID_BUTTON_1, 45, 71, 150, 50, 0, 0x0, 0 },
      5. //{ BUTTON_CreateIndirect, "3", ID_BUTTON_2, 45, 135, 150, 50, 0, 0x0, 0 },
      6. //{ BUTTON_CreateIndirect, "4", ID_BUTTON_3, 45, 199, 150, 50, 0, 0x0, 0 },
      7. //{ BUTTON_CreateIndirect, "5", ID_BUTTON_4, 45, 263, 150, 50, 0, 0x0, 0 },
      8. // USER START (Optionally insert additional widgets)
      9. { BUTTON_CreateIndirect, (char *)stringa1, ID_BUTTON_0, 45, 7, 150, 50, 0, 0x0, 0 },
      10. { BUTTON_CreateIndirect, (char *)stringa2, ID_BUTTON_1, 45, 71, 150, 50, 0, 0x0, 0 },
      11. { BUTTON_CreateIndirect, (char *)stringa3, ID_BUTTON_2, 45, 135, 150, 50, 0, 0x0, 0 },
      12. { BUTTON_CreateIndirect, (char *)stringa4, ID_BUTTON_3, 45, 199, 150, 50, 0, 0x0, 0 },
      13. { BUTTON_CreateIndirect, (char *)stringa5, ID_BUTTON_4, 45, 263, 150, 50, 0, 0x0, 0 },
      14. // USER END
      15. };
      But I have no idea how to hide a button or not
      I want to insert in _cbDialog - > case WM_INIT_DIALOG (as just done here), a switch-case that configure Buttons hide/show.
      How Can I do that ?
      To show and hide widgets/windows you can use the routines WM_ShowWindow() and WM_HideWindow().
      A switch-case like in WM_NOTIFY_PARENT won't work in WM_INIT_DIALOG. WM_INIT_DIALOG is only sent once to the parent dialog, after it has been initialized. In WM_INIT_DIALOG, you can retrieve the button handles from the IDs by using WM_GetDialogItem(), e.g. WM_GetDialogItem(pMsg->hWin, ID_BUTTON_0).
      After you have retrieved the button handle, you can e.g. hide the widget, or call any of the BUTTON_* routines to edit the widget's properties, e.g. the button text with BUTTON_SetText().
      Florian
    • HI Florian,
      Thanks. I thought WM_HideWindow() was only used for windows or screen areas, not widgets.
      Switch-case work fine, in WM_INIT_DIALOG I have inserted the following code which hides buttons 1 and 5 with screen_1 and only button 1 with screen_2
      1. for (i = 0; i < 5; i++) {
      2. hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_0 + i);
      3. WIDGET_SetFocusable(hItem, 0);
      4. switch(State_Screen){
      5. case SCREEN_1:
      6. if((i == 4) || (i == 0)){
      7. WM_HideWindow(hItem);
      8. }
      9. case SCREEN_2:
      10. if(i == 0){
      11. WM_HideWindow(hItem);
      12. }
      13. if(i == 4){
      14. WM_ShowWindow(hItem);
      15. }
      16. break;
      17. default:
      18. break;
      19. }
      20. }
      I have a second question: I have to insert an image that resides in FLASH in the screen created by GUIBuilder.
      The image is inserted with this string:
      1. { IMAGE_CreateIndirect, "Image", ID_IMAGE_0, 93, 7, 50, 50, 0, IMAGE_CF_MEMDEV, 0 },
      If I use draex outside the GUIBuilder, the image is displayed correctly
      1. GUI_BMP_DrawEx(GUI_ReadFromFlash, (void *)&(IMPOSTAZIONE), 90, 1);
      Thanks.
      Widgets are windows, that means the Window Manager API routines (prefixed with WM_) also work with widgets.
      You can set the external BMP image to the widget with IMAGE_SetBMPEx().
      Florian
