[SOLVED] How to fix a J-Link?
  • [SOLVED] How to fix a J-Link?
    Hello, during the update of the firmware of my J-Link edu, the usb cable was disconnected from my computer and it is now damaged, there is no communication.
    I want to know is it possible to fix my j-link in China?
    plugging the USB cable during the FW update does not damage the J-Link.
    All that happens is that the update is incomplete and next time you power it, it will remain in BTL mode.
    In this mode, when starting J-Link Commander, you will see this:
    Confirm with "OK", let it do its magic and that's it.
  • Hello, I have tried but there is no firmware restoration confirmation window. Here is what the command window prompts.
    Shell-Script
    1. Connecting ...
    2. - Connecting via USB to probe/ programmer device 0
    3. - Probe/ Programmer firmware: J-Link V11 compiled Dec 1 2021 16:59:54
    4. - Device "S32K144" selected.
    5. - Target interface speed: 4000 kHz (Fixed)
    6. - VTarget = 5.051V
    7. - InitTarget() start
    8. - InitTarget()
    9. - Connect Under Reset
    10. - Communication error while accessing MDM-AP.
    11. - Connect Under Reset
    12. - InitTarget() end
    13. - InitTarget() start
    14. - InitTarget()
    15. - Connect Under Reset
    16. - Communication error while accessing MDM-AP.
    17. - Connect Under Reset
    18. - InitTarget() end
    19. - ERROR: Failed to connect.
    20. Could not establish a connection to target.
  • You are not getting an FW restoration dialog because your FW is not damaged….
    As I wrote before: Unplugging J-Link during the FW update does not damage it.
    It is more likely that your setup is broken (broken wires etc) or you programmed something into the chip that made it unresponsive to debug & programming requests.
