[SOLVED] Can't Program Binary into the micro-controller
  • [SOLVED] Can't Program Binary into the micro-controller
    Hello Everyone
    I am working on a project using micro-controller MKE15Z and using J-Link Plus.
    Today when I tried to program the binaries using J-Flash, I get some programming error, I recently updated to version 7.58b and 7.58c of the J-Link tool. (Earlier everything was working fine, I don't know why it is not working maybe due to version change, I am not sure)
    My project is divided into two parts, configuration and firmware and both are the part of micro-controller's flash, with IAR I am not able to program the configuration (it's starting address is different).
    But when I used J-Flash two flash both binaries, I get the following error message.
    1. - Connecting ...
    2. - Connected successfully
    3. - Checking if selected data fits into selected flash sectors.
    4. - Start of preparing flash programming
    5. - End of preparing flash programming
    6. - Start of determining dirty areas in flash cache
    7. - End of determining dirty areas
    8. - CPU speed could not be measured.
    9. - Start of erasing sectors
    10. - Blank checking 0x00000000 - 0x0001FFFF
    11. - Erasing range 0x00000000 - 0x0001FFFF ( 64 Sectors, 128 KB)
    12. - Blank checking 0x00020000 - 0x000367FF
    13. - Erasing range 0x00020000 - 0x000367FF ( 45 Sectors, 90 KB)
    14. - End of erasing sectors
    15. - Start of flash programming
    16. - Programming range 0x00000000 - 0x00007FFF ( 16 Sectors, 32 KB)
    17. - ERROR: Programming failed @ address 0x00000000 (Algo91: Illegal command)
    18. - End of flash programming
    19. - ERROR: Program failed
    20. - Start of restoring
    21. - ERROR: Timeout while restoring target, RAMCode did not respond in time. (PC = 0xC5C4390C, CPSR = 0xCBD0A908, LR = 0x21000000)!
    22. - ERROR: Failed to restore target. RAMCode never stops
    23. - End of restoring
    24. - ERROR: Failed to auto program target
    25. Disconnecting ...
    26. - Disconnected
    As per the above logs I can't even program anything.
    I read on internet and found some links where the steps on unlock the micro is given, and I tried that also.
    Below are the unlocking logs from J-Link Commander.
    1. Connecting to target via SWD
    2. InitTarget() start
    3. InitTarget()
    4. InitTarget() end
    5. Found SW-DP with ID 0x0BC11477
    6. DPIDR: 0x0BC11477
    7. CoreSight SoC-400 or earlier
    8. Scanning AP map to find all available APs
    9. AP[2]: Stopped AP scan as end of AP map has been reached
    10. AP[0]: AHB-AP (IDR: 0x04770031)
    11. AP[1]: JTAG-AP (IDR: 0x001C0020)
    12. Iterating through AP map to find AHB-AP to use
    13. AP[0]: Core found
    14. AP[0]: AHB-AP ROM base: 0xF0002000
    15. CPUID register: 0x410CC601. Implementer code: 0x41 (ARM)
    16. Found Cortex-M0 r0p1, Little endian.
    17. FPUnit: 2 code (BP) slots and 0 literal slots
    18. CoreSight components:
    19. ROMTbl[0] @ F0002000
    20. [0][0]: F0000000 CID B105900D PID 001BB932 MTB-M0+
    21. [0][1]: F0001000 CID B105900D PID 0008E000 MTBDWT
    22. [0][2]: E00FF000 CID B105100D PID 000BB4C0 ROM Table
    23. ROMTbl[1] @ E00FF000
    24. [1][0]: E000E000 CID B105E00D PID 000BB008 SCS
    25. [1][1]: E0001000 CID B105E00D PID 000BB00A DWT
    26. [1][2]: E0002000 CID B105E00D PID 000BB00B FPB
    27. Cortex-M0 identified.
    28. J-Link>unlock Kinetis
    29. Found SWD-DP with ID 0x0BC11477
    30. Unlocking device...O.K.
    31. J-Link>
    Even after this nothing works.
    Then I used another laptop with some older version of J-Flash software and it works well, and then I tried on the same computer and it doesn't work.
    Can someone please try to help me, what can be the issue?
    Edited:
    Another update from my side, I just downgraded the version number of J-Flash software on the same laptop and it works fine. I don't know what exactly gone wrong with the newer version of J-Flash software or there is something else.
    The post was edited 1 time, last by arun.sh: Some Updates ().
    Could you please send us a J-Link log file? How to enable:
    Could you please tell us which is the last version this is working with?
    Thanks for your reply, but since this is a very old topic, I don't have much information because the problem is no more reproducible on my laptop.
    Last time I fixed the issue with version 6.86f, and at the moment I am using v7.60b and I don't have any issues.
    If in future I faced the same issue again, I will take the logs as mentioned by you in the post. thanks
    Good to hear that you are up and running again.
