Data Trace with Jtrace PRO and Ozone on ARM R5 core!
    • Data Trace with Jtrace PRO and Ozone on ARM R5 core!
      New
      Hi.
      My setup has ARM R5 core with JTrace PRO and ozone debugger. It has 4 Trace data pins and 1 pin for trace clock (totally 5 pins).
      I am trying to evaluate/explore the data trace part of it, but observing that the data sampling is happening at approx. 500Hz (2 msecs) on the ozone timeline view (In the first attachment, in timeline view you can observe this ). I’m just incrementing and decrementing two counters (global variables).
      Observed the same result (data sampling of 500 Hz) when clock is running at 40 MHz or 80 MHz.
      Observed the same result (data sampling of 500 Hz) when selecting 10Khz (no changes with any rate) sampling setting on OZONE .
      Please help me with this!
      Prashanth
    • New
      Hello Prashanth,
      Please note that the data trace that you refer here to is independent from the 5 pin trace that you use for instruction tracing.
      Instead it uses the debug interface and HSS.
      segger.com/products/debug-prob…#data-acquisition-via-hss
      Just for awareness.
      How do you detect the 500 Hz sampling frequency? From the screenshots it is not apparent.
      If you refer to unexpected timeline values, make sure that under trace settings the correct CPU clock speed is set.
      Otherwise the x-axis on the timeline will be wrong.
      To see the actual data samples open the Data Sampling window under View->Data Sampling and then open the Samples tab.
      There you should see data samples approximately at the frequency that you have set as the sampling frequency.
      Can you confirm?
    • New
      Hi Nino,
      Thanks for your reply!
      I understand that the 5 pin trace are not responsible for the data tracing. So how can we enable data tracing on Ozone then?
      Is 5 pin trace only used for instruction and cycle accurate traces?
      On the other things, I increased JTAG interface speed to 25 Mhz (from 4Mhz earlier) , but am still able to see data trace going up to approx 2Khz only. Please find the attachment of all the settings, clock and sampling window as well.
      Sampling Frequency on the Data sampling window has NO effect.
    • New
      It is not supported. Data tracing is only supported by a hand full of Cortex-A and -R devices and would require a 16 bit trace interface to avoid overflows.
      As our customers typically do not want to waste so many pins for just debugging we do not provide a trace probe for such interface and feature.
      Correct.
      Ok I see. This is reproducible. We will look into this and fix it.
    • New
      Hello Prashanth,
      data trace via the trace pins is not supported by either J-Trace Pro nor Ozone.
      Currently there are no plans to add support for this for the existing trace probes.
    • New
      There is no data trace support available in our tools or software.
      You can of course extract the ETB data manually and write your own analyzer but this is outside of our support scope.
      For this the trace data can be dumped into a trace file:
      wiki.segger.com/J-Link_Command_Strings#TraceFile
      But for data trace you would have to overwrite our default trace init of the Arm Coresight componetns (ETM, TPIU, etc.) with a JlinkScript:
      wiki.segger.com/J-Link_script_files
      Please understand that we can't provide any support for this.
    • New
      Thank you Nino!
      I have also witnessed that my instruction trace data is wiped off after resuming from a breakpoint , if I hit another breakpoint, do not see all the instruction trace. Is this normal ? What to do if I want the complete data?
      I believe the instruction tracing in unlimited right ?
