Draw a line above a text
    • Draw a line above a text
      Hello.
      I need to draw a line above a text.
      The text is created using a dialog box
      Whne I try to draw the line in WM_PAINT message, the line is drawn bellow the text.
      Note that the text has a background collor.
      Here is the example code:
      1. #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
      2. #define ID_TEXT_0 (GUI_ID_USER + 0x02)
      3. // USER START (Optionally insert additional defines)
      4. // USER END
      5. /*********************************************************************
      6. *
      7. * Static data
      8. *
      9. **********************************************************************
      10. */
      11. // USER START (Optionally insert additional static data)
      12. // USER END
      13. /*********************************************************************
      14. *
      15. * _aDialogCreate
      16. */
      17. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
      18. { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 320, 240, 0, 0x0, 0 },
      19. { TEXT_CreateIndirect, "Text", ID_TEXT_0, 50, 130, 320, 82, 0, 0x0, 0 },
      20. // USER START (Optionally insert additional widgets)
      21. // USER END
      22. };
      23. /*********************************************************************
      24. *
      25. * Static code
      26. *
      27. **********************************************************************
      28. */
      29. // USER START (Optionally insert additional static code)
      30. // USER END
      31. /*********************************************************************
      32. *
      33. * _cbDialog
      34. */
      35. static void _cbDialog(WM_MESSAGE * pMsg) {
      36. // USER START (Optionally insert additional variables)
      37. // USER END
      38. WM_HWIN hItem;
      39. switch (pMsg->MsgId) {
      40. // USER START (Optionally insert additional message handling)
      41. // USER END
      42. case WM_INIT_DIALOG:
      43. hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
      44. TEXT_SetText(hItem, "Text");
      45. TEXT_SetBkColor(hItem, GUI_YELLOW);
      46. case WM_PAINT :
      47. GUI_SetColor(GUI_BLACK);
      48. GUI_SetPenSize(1);
      49. GUI_DrawLine(0, 0, 320, 240);
      50. break;
      51. default:
      52. WM_DefaultProc(pMsg);
      53. break;
      54. }
      55. }
      56. WM_HWIN CreateWindow22(void)
      57. {
      58. WM_HWIN hWin;
      59. hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
      60. return hWin;
      61. }
      62. void MainTask(void) {
      63. GUI_Init();
      64. CreateWindow22();
      65. while (1)
      66. {
      67. GUI_Exec();
      68. }
      69. }
      The result is :
      you can simply create another window over the existing one to draw over the rest.
      Try this:
      1. #include "DIALOG.h"
      2. #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
      3. #define ID_TEXT_0 (GUI_ID_USER + 0x02)
      4. // USER START (Optionally insert additional defines)
      5. // USER END
      6. /*********************************************************************
      7. *
      8. * Static data
      9. *
      10. **********************************************************************
      11. */
      12. // USER START (Optionally insert additional static data)
      13. // USER END
      14. /*********************************************************************
      15. *
      16. * _aDialogCreate
      17. */
      18. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
      19. { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 320, 240, 0, 0x0, 0 },
      20. { TEXT_CreateIndirect, "Text", ID_TEXT_0, 50, 130, 320, 82, 0, 0x0, 0 },
      21. // USER START (Optionally insert additional widgets)
      22. // USER END
      23. };
      24. /*********************************************************************
      25. *
      26. * Static code
      27. *
      28. **********************************************************************
      29. */
      30. // USER START (Optionally insert additional static code)
      31. // USER END
      32. static void _cbDrawingWindow(WM_MESSAGE * pMsg) {
      33. switch (pMsg->MsgId) {
      34. case WM_PAINT:
      35. GUI_SetColor(GUI_BLACK);
      36. GUI_SetPenSize(1);
      37. GUI_DrawLine(0, 0, 320, 240);
      38. break;
      39. default:
      40. WM_DefaultProc(pMsg);
      41. break;
      42. }
      43. }
      44. /*********************************************************************
      45. *
      46. * _cbDialog
      47. */
      48. static void _cbDialog(WM_MESSAGE * pMsg) {
      49. // USER START (Optionally insert additional variables)
      50. int xSize;
      51. int ySize;
      52. // USER END
      53. WM_HWIN hItem;
      54. switch (pMsg->MsgId) {
      55. // USER START (Optionally insert additional message handling)
      56. // USER END
      57. case WM_INIT_DIALOG:
      58. hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
      59. TEXT_SetText(hItem, "Text");
      60. TEXT_SetBkColor(hItem, GUI_YELLOW);
      61. xSize = WM_GetWindowSizeX(pMsg->hWin);
      62. ySize = WM_GetWindowSizeY(pMsg->hWin);
      63. WM_CreateWindowAsChild(0, 0, xSize, ySize, pMsg->hWin, WM_CF_SHOW | WM_CF_HASTRANS, _cbDrawingWindow, 0);
      64. //case WM_PAINT :
      65. // GUI_SetColor(GUI_BLACK);
      66. // GUI_SetPenSize(1);
      67. // GUI_DrawLine(0, 0, 320, 240);
      68. // break;
      69. default:
      70. WM_DefaultProc(pMsg);
      71. break;
      72. }
      73. }
      74. WM_HWIN CreateWindow22(void)
      75. {
      76. WM_HWIN hWin;
      77. hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
      78. return hWin;
      79. }
      80. void MainTask(void) {
      81. GUI_Init();
      82. CreateWindow22();
      83. while (1)
      84. {
      85. GUI_Exec();
      86. }
      87. }
      88. /*************************** End of file ****************************/
      Please note that any underlaying windows/widget will no longer receive touch input with the window in the foreground.
