I have bought a P Nucleo WB55 develop board from the website st.com/en/evaluation-tools/p-nucleo-wb55.html.
The onboard ST-LINK works well when I received it.
But I want to use it with the J-Link OB which is needed in my research project.
As a result, I convert the onboard ST-LINK to the J-Link OB following the steps of the link segger.com/products/debug-prob…j-links/st-link-on-board/ and the P Nucleo WB55 is supported.
However, the error is hit when debugging with the J-Link OB.
The error message is as below. Could you please help to figure out the problem?
Thanks for your help.
LWQ wrote:
Disabled output of control characters
J-Link software found at: C:/Program Files/SEGGER/Ozone/JLink_x64.dll
File.NewProjectWizard();
Target core support plugin loaded.: C:/Program Files/SEGGER/Ozone/Plugins/Core/CorePluginARM.dll
Project.SetDevice ("STM32WB55RG");
Project.SetHostIF ("USB", "775796554");
Project.SetTargetIF ("SWD");
Project.SetTIFSpeed ("4 MHz");
Project.AddSvdFile ("$(InstallDir)/Config/CPU/Cortex-M4F.svd");
File path resolved: "$(InstallDir)/Config/CPU/Cortex-M4F.svd" was found at "C:/Program Files/SEGGER/Ozone/Config/CPU/Cortex-M4F.svd"
File.Open ("C:/Users/lwq/Downloads/en.stm32cubewb_v1-12-0_v1.12.0/STM32Cube_FW_WB_V1.12.0/Projects/P-NUCLEO-WB55.Nucleo/Applications/BLE/BLE_HeartRate/Binary/BLE_HeartRate_reference.hex");
Debug.Start();
Device "STM32WB55RG" selected.
Found SW-DP with ID 0xCBA02477
DPv0 detected
AP[2]: Stopped AP scan as end of AP map has been reached
AP[1]: AHB-AP (IDR: 0x84770001)
AP[0]: Core found
FPUnit: 0 code (BP) slots and 0 literal slots
CoreSight components:
ROMTbl[0] @ E00FF000
SetupTarget() start
WARNING: Secure Firmware detected @ 0x080FF000
Connecting to target AP[0]/Cortex-M4
CORE ID AP[0]:0x080FF000
CPU could not be halted
CORE ID AP[0]/Cortex-M4 is not halted!
SetupTarget() end
DPv0 detected
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[0]: Core found
SetupTarget() start
SetupTarget() end
Connection failed.
