[SOLVED] -nogui documentation request
  • [SOLVED] -nogui documentation request
    Can documentation for -nogui be added in the the user manual for jlink.exe?
    The UM08001_JLink.pdf from the v7.56b package only mentions -nogui for the GDB Server and worse it makes no mention of the required argument (-nogui 1 is needed for jlink.exe). Perhaps GDB Server doesn't need the "1" argument? This led to a bit a head scratching about why jlink.exe would complain about "Missing command line parameter after command -NoGui". (why does -nogui need an argument anyway?)
    Also, the release notes for commander and some forum posts indicate that -nogui is documented on the wiki (wiki.segger.com/J-Link_Commander#-NoGui), but that isn't the case. The J-Link Commander Wiki page doesn't mention -nogui at all (maybe it was removed for some reason?).
    The post was edited 1 time, last by mwb1100 ().
    The -NoGui command was lost when the wiki page was reworked.
    We corrected the J-Link Commander documentation accordingly:
    wiki.segger.com/J-Link_Commander#Batch_processing
    Thank you for making this known to us.
    The J-Link Commander requires parameters for all command line options for historical reasons.
    In theory, there are multiple command line options that would not require a specific value to work (-AutoConnect, -ExitOnError, -NoGui).
    However it was decided against changing the behavior in retrospect,
    a) to stay backwards compatible and
    b) to stay consistent with the current command line scheme used for the J-Link Commander.
    Does this answer your questions?
    Good to hear that you were able to figure it out even while the documentation was lacking.
