[SOLVED] APIs supported by JLinkSDK.cs
  • [SOLVED] APIs supported by JLinkSDK.cs
    I just purchased the JLink SDK, v7.56 to use in developing a C#-based application. The SDK comes with a JLinkSDK.cs file to interface with the JLinkDLL, but it does not have all the APIs listed in the SDK Users Manual.
    In particular, I need the [snipped by moderator] APIs, and possibly the [snipped by moderator] API, because that is used in the C examples instead of the [snipped by moderator] API, which I suspect can be used instead.
    Are we expected to use the JLinkSDK,cs as a template example for adding APIs? It seems that the currtent version includes only those APIs that are used by the C# example programs.
    Lee
    The post was edited 1 time, last by SEGGER - Fabian ().
  • Hi Lee,
    as stated in the license agreement of the J-Link SDK,
    it is forbidden to discuss the J-Link API or J-Link SDK Samples openly.
    I edited your post accordingly.
    Support for the J-Link SDK is provided via the J-Link Support system only.
    A Link to the support system can be found in my signature, below this post.
