J-Flash V7.54d -- ERROR: Could not open flash device list file
    • J-Flash V7.54d -- ERROR: Could not open flash device list file
      I get the following error when I start J-Flash in any directory under /home : ERROR: Could not open flash device list file [ETC/JFlash/Flash.csv]
      The contents of JFlash.log is following:
      Source Code: JFlash.log
      1. Application log started
      2. - J-Flash V7.54d (J-Flash compiled Sep 28 2021 16:18:47)
      3. - JLinkARM.dll V7.54d (DLL compiled Sep 28 2021 16:18:25)
      4. Reading flash device list [ETC/JFlash/Flash.csv] ...
      5. - ERROR: Could not open flash device list file [ETC/JFlash/Flash.csv]
      6. File not found!
      The host system is Ubuntu. Installation is as follows:
      1. > ls /opt/SEGGER
      2. drwxrwxr-x JLink_Linux_V754b_x86_64
      3. drwxrwxr-x JLink_Linux_V754d_x86_64
      4. drwxr-xr-x Ozone_Linux_V324d_x86_64
      5. drwxr-xr-x Ozone_Linux_V324f_x86_64
      6. lrwxrwxrwx JLink -> JLink_Linux_V754d_x86_64
      7. lrwxrwxrwx Ozone -> Ozone_Linux_V324f_x86_64
      8. > which JFlashExe
      9. /usr/local/bin/JFlashExe
      10. > ls /usr/local/bin/JFlashExe
      11. lrwxrwxrwx /usr/local/bin/JFlashExe -> /opt/SEGGER/JLink/JFlashExe
      If I cd /opt/SEGGER/JLink (or cd /opt/SEGGER/JLink_Linux_V754d_x86_64 for that matter) and start JFlash from there, everything is fine, the log message is
      4. Reading flash device list [./ETC/JFlash/Flash.csv] ...
      5. - List of flash devices read successfully (451 Devices)
      6. Reading MCU device list ...
      7. - List of MCU devices read successfully (8788 Devices)
      It would be nice if this issue is solved.
      Kind regards,
      Vadim Barshaw
    • Hi Vadim,
      Just to make sure that I understood you correctly:
      - You installed J-Link via DEB-package
      - You changed your directory to the home directory (cd ..).
      - Calling "JFlashExe" or "JFlash" from there caused the mentioned error
      Is that correct?
      If so, we are not able to reproduce this issue on our side (see below).
      Could you please provide step-by-step instructions on how to reproduce this issue?
