J-Scope 7.54c use with J-link RTT client 7.54c error that kills gdb session
    • J-Scope 7.54c use with J-link RTT client 7.54c error that kills gdb session
      Hello guys!
      We are also happy to see some news about J-scope. Such a great tool!
      We are used to use J-scope 611j RTT (it plots 6x int32_t @ 20kHz with "SEGGER_RTT_MODE_NO_BLOCK_SKIP" on channel 1) with J-link 631a RTT client (this terminal is used to display and received command on channel 0), gdb and dll and that was the only known combination that worked for us. Because of this only compatibility we couldn't update to a new j-link version otherwise J-scope wouldn't work anymore.
      As we saw the new version 7.54c of all you program suite, we installed the new j-scope and j-link package.
      We've been really careful to uninstall previous version and we updated in our IDE the call for the new version of GDB supplied.
      Unfortunately since the new version is installed, when both RTT client and j-scope are launched it works rarely and the whole session bug.
      That happens when I push play/stop in J-scope with RTT option.
      The screenshot of typical raised errors are attached, it says : J-link low on memory and communication timed out with mismatch of request and receive bytes
      And sometimes I succeed to have both working, terminal and j-scope, but for no reason J-scope crashes and close with no information.
      It is linked to parallel use of the terminal and j-scope.
      Are you aware of that kind of issues?
      We use J-link Ultra+ with a MKE16f512 Kinetis MCU from NXP and with MCUxpresso that launches SEGGER J-Link GDB Server.
      Sincerely,
      thank you for the feedback.
      We are not aware of such an issue. I will try to reproduce it and get back to you with my results.
      Matthias
      sorry for the delayed response, there were a lot of interrupts.
      I tried to reproduce the issue, but am not sure that I have a complete picture of the setup you are using.
      Would it be possible for you to provide the following?
      • The elf file
      • The code for the RTT initialization and usage
      • A detailed step-by-step reproduction guide
      • A short screen recording demonstrating the issue
      Parallel usage can be a complex issue for which we would need as much information as possible.
      Matthias
