Hello
I have observed from log files that when I execute from script file the loadbin command, Jlink also does a checkup if the binfile is already in MCU flash memory; then it is erasing it, andthen it programs the bin file; after that it checks again if the bin file is in the MCU memory.
Right now I am erasing the chip and then use the loadbin command.
It is safe to skip the erase step?
Is the erasing embbeded into loadbin command equivalent to erase command ?
