[SOLVED] Cannot refer to float variable in J-SCOPE V7.54
  • [SOLVED] Cannot refer to float variable in J-SCOPE V7.54
    Hello.
    I'm sorry if my English is strange because I'm using editing and translation software.
    Let me ask you a question.
    I want to monitor a float variable in J-scope, but I can't select it because I can't check the box.
    (See image)
    In previous versions of j-scope (e.g., V6.11m), you were able to select the float variable (from the article at the following URL), but due to the version upgrade, you are no longer able to do so?
    qiita.com/motorcontrolman/items/c1910c5a51fb29a700fd
    Please let me know if there is anything I can do to monitor the float variables.
    Thank you for your time.
    As you also opened a ticket in our support ticket system for this request, we will close this thread now and answer you there.
    Please keep information to one channel for future requests.
    Otherwise, this causes a higher workload on our site,
    resulting in longer response times and critical information might get lost.
