I am trying to build a Nordic nRF based project with SES 5.60a however I got the following linker error:
imgur.com/a/gQo7DYW
The object files are visible and readable by the SES itself:
imgur.com/a/LJN76SD
If I ran the linker command from a terminal the linker runs fine and produces the outputs:
imgur.com/a/VVr8I53
I ran the SES with the same user as I ran in terminal.
I have also tried to run SES with sudo but the results are the same.
I am running a stock Ubuntu 20.04
I tried to disable apparmor, but it did not helped.
Did anyone faced with similar? Any ideas what else shall I check would be highly welcome!
The object file seems to be changed each build, so it could be some sequencing issue as well.
imgur.com/a/gQo7DYW
imgur.com/a/LJN76SD
imgur.com/a/VVr8I53
The post was edited 1 time, last by martonmiklos ().
