[SOLVED] Prevent Ozone from downloading Firmware - just attaching to target
  • [SOLVED] Prevent Ozone from downloading Firmware - just attaching to target
    is there a possibility to configure Ozone "never" to download the selected ELF file?
    I currently try to debugging a production device and want to avoid the downloading of the firmware accidentally.
    I just need to select "Attach to Running Target". But I know, there will be the time when I will just click "Download & Reset Target" accidentally.
    Kind regards
    Andreas
  • Hi Andreas,
    It is possible to explicitly set the connect mode in the OnProjectLoad() function of the project:
    Debug.SetConnectMode( CM_ATTACH_HALT );
    Does this answer your question?
