[SOLVED] Is there a lower limit on the reference voltage for the J-Link?
  • [SOLVED] Is there a lower limit on the reference voltage for the J-Link?
    Hi
    I have built a board using the NRF52840 chip.
    When trying to connect to it, I get the message "Target Voltage Too Low".
    The NRF chip has a default reference voltage of 1.8V before it's set otherwise in the software.
    I have measured the voltage from the chip all the way to the input pin of the Jlink.
    So it should be able to read it.
    Is there a lower limit for the reference voltage? Is 1.8V too low?
    Or is there anything else I need to check?
    All help appreciated.
    The lower limit for a full J-Link (BASE, PLUS, …, not! EDU Mini) is 1.2V.
    Can you please give this a try and post the *complete* output?
  • Hi
    Thanks for the response.
    i managed to locate the problem.
    The mating connector on my board had been mirrored, and I got around it by making a custom cable.
    Everything is working fine now.
    Best Regards
    Verner
  • Hi Verner,
    Good to hear that you found a solution.
