[SOLVED] IDEA: Need 3D graphic debug tool for Segger IDE
  • [SOLVED] IDEA: Need 3D graphic debug tool for Segger IDE
    I need a 3D graphic tool that plugs in or is built into the Segger IDE that allows me to debug trigonometric and geometry functions in 3D graphic space.
    Needed Features:
    I want to observe xyz cartesian coordinates converted to polar coordinates and back again, displayed within a 3D sphere.
    I want to graphically observe an accelerometer's xyz motion vector displayed inside a sphere in real-time, while the firmware hardware is running.
    I want to graphically observe a magnetometer's North pole vector displayed inside a sphere in real-time, while the firmware hardware is running.
    I want to graphically observe an accelerometer's determined 1G gravitational vector inside a sphere in real-time.
    I want to observe all of the above at the same time.
    Observing such things allows a software developer to confirm the validity of the geometric functions.
    The graphic tool works like this:
    The project's C firmware source code invokes a graphic tool with a collection of coordinates as parameters, such as xyz coodinates, vector color, vector thickness, backdrop sphere, etc.
    Then during a Segger IDE debug session, the following occurs...
    A popup graphic window appears showing the graphic vectors and objects in 3D space, very similar to observing a small video game.
    The graphic tool displays the coordinates as one or more vectors rotating around a sphere graphic object.
    Each vector can be color controlled by the debugging software, whereby a software developer can readily confirm that various geometric functions are working correctly.
    It seems to me that debugging software means more than a text trace in a console window. Debugging can also be visual in a 3D graphic space. It's a faster and more reliable approach to graphic and geometric functions.
    Is there such a tool anywhere in the marketplace?
    If not, I would like to see Segger or another 3rd party company build this tool. IT IS VERY MUCH NEEDED! [img]https://forum.segger.com/wcf/images/smilies/tongue.png[/img]
    Ken Huebner
    Software Developer
  • Hello Ken,
    We are not aware of such tool that would be available.
    While we see the appeal of having a sensor and function output visualized in 3D space, such tool would only be useful to a very small fraction of our customer base so currently there are no plans to create such tool.
    Should you be interested in creating such software yourself the J-Link SDK could be used:
    It is the same SDK that was used to create all our J-Link and debug software tools.
