[SOLVED] [J-Link Commander] STM32 - default behavior when active read protected STM32 device detected.
  • [SOLVED] [J-Link Commander] STM32 - default behavior when active read protected STM32 device detected.
    On 2 different computer with 2 different j-link compact plus, we got 2 different behavior when we connect to a STM32 and the STM32 has the active read protection activated.
    Behavior 1: J-Link Commander automatically disable read protection
    1. SEGGER J-Link Commander V7.52b (Compiled Aug 3 2021 16:59:02)
    2. DLL version V7.52b, compiled Aug 3 2021 16:57:43
    3. J-Link Command File read successfully.
    4. Processing script file...
    5. J-Link connection not established yet but required for command.
    6. Connecting to J-Link via USB...O.K.
    7. Firmware: J-Link V10 compiled Jul 28 2021 10:07:03
    8. Hardware version: V10.10
    9. S/N: 850100385
    10. License(s): RDI, FlashBP, FlashDL, JFlash, GDB
    11. VTref=1.786V
    12. Target connection not established yet but required for command.
    13. Device "STM32L443RC" selected.
    14. Connecting to target via SWD
    15. Found SW-DP with ID 0x2BA01477
    16. Active read protected STM32 device detected.
    17. This could cause problems during flash download.
    18. Note: Unsecuring will trigger a mass erase of the internal flash.
    19. Executing default behavior previously saved in the registry.
    20. Device will be unsecured now.
    Behavior 2: unsecure step is skipped
    1. SEGGER J-Link Commander V6.86f (Compiled Oct 23 2020 18:01:48)
    2. DLL version V6.86f, compiled Oct 23 2020 18:00:13
    7. Firmware: J-Link V10 compiled Nov 12 2020 10:06:35
    9. S/N: 850100261
    11. VTref=1.791V
    13. Device STM32L443RC selected.
    20. Skipping unsecure.
    We would like to have the same behavior on all our PC: skip unsecure step.
    Log indicated that some default behavior is executed: "Executing default behavior previously saved in the registry"
    Is it possible to update the default behavior?
  • We found out how to change the behavior... It is stored in registry (Computer\HKEY_CURRENT_USER\Software\SEGGER\J-Link\DontShowAgainUnlockSTM)
    The first time user has a pop up to select the behavior, if he ticks the "remember" box, the entry is saved in registry.
    To change the behavior later on, entry can be deleted, then the pop up will show again.
    Link to the official documentation:
    wiki.segger.com/UM08001_J-Link…#Reset_unlock_message_box
