[SOLVED] c++ compiler and linker options?
  • [SOLVED] c++ compiler and linker options?
    I want to create a C++ project for a Nordic BLE device. What would be the appropriate compiler and linker options if the goal is to be MISRA compliant? Is there a way to automate this configuration in the future?
    Please note that this is no support forum. For more information see my signature.
    Regarding your question. What do you mean with MISRCA compliant toolchain options?
    MISRA only defines a coding style. It does not give any guidelines for the compiler or linker.
    If you are looking for a MISRA check/analysis tool for Embedded Studio then you would need to use an external tool.
    You can then add it to Embedded Studio as an external Link/MISRA tool which then can be started from the context menu for example.
    For more information on how to implemented external tools in Embedded Studio see here:
    studio.segger.com/index.htm?ht…nal_tools_file_format.htm
    The default implementation shows an example for PC-Lint which supports MISRA for example.
