[SOLVED] J-Link Emulator for AM437x in CCS (TI)
  • [SOLVED] J-Link Emulator for AM437x in CCS (TI)
    the SEGGER J-Link JTAG emulators are supported in CodeComposerStudio and the TI AM4377 processor is supported by SEGGER. However, the AM4377 is not yet enabled in CCS.
    From TI I got the following response:
    Hello Bernd,
    The J-Link package in CCS does not appear to come with the driver XML file for the Cortex-A9. Hence AM437x does not appear to be supported in CCS.
    Looks like they have had J-Link support for it for awhile, but still has not added support for it in CCS
    https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/852385/ccs-am4372-does-iar-j-link-support-am437x-i-e-cortex-a9
    https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/815282/ccs-am4377-debug-connection-over-segger-j-link-not-allowed
    As mentioned in the above threads, support for this would have to come from Segger. It is best to contact them directly.
    ki
    Might it be possible for SEGGER to add the support for it in CCS?
    Thanks a lot for your help,
    have a nice day,
    Bernd
  • Hi Bernd,
    I will raise this topic on our next internal meeting and come back to you with the results.
  • Hi Bernd,
    We implemented Cortex-A9 support for the J-Link CCS Plugin.
    A new version containing this feature is planned to be released sometime next week.
  • Hi Bernd,
    You should be able to update it from within CCS:
    segger.com/products/debug-prob…pdating-j-link-inside-ccs
  • Hello Fabian,
    I tried to use the latest J-Link files, but I couldn't get it working. When changing the target configuration in CCS from TI-Debug-probe to <Segger J-Link Emulator> I still get the error message <Unable to find appropriate device driver for connection type "JLink" and isa "CortexA9">. The versions I get from the update site (download.segger.com/J-Link/JLink_TI_CCS_plugin_unified) are:
    • <SEGGER J-Link USB-Driver> 1.0.0.6
    • <SEGGER J-Link Support> 7.52.4.0.
    Are these the correct ones or am I using the wrong update-site?
    have a nice day,
    Bernd
    PS: I am using CCS 10.4.0.6
    The post was edited 1 time, last by Bernd Sprenger ().
    I checked and we did indeed not upload the version with the A9 Support.
    It should now be available via Help -> Check for Updates (7.56.2.0)
    Could you please try again and tell us if it now works as expected?
  • Hello Fabian,
    it downloads the update support and driver files, but unfortunately it still doesn't work (even after a clean-install of CCS) - When switching in my "Target Configuration" from "Blackhawk" to "Segger J-Link Emulator" I still get the error message [Unable to find an appropriate device driver for the connection type "JLink" and isa "CortexA9"]...
    The following Segger support & drivers are installed:
    • Segger J-Link Support (Windows x86_64): 7.56.2.0
    • Segger J-Link USB Driver: 1.0.1.0
    Bernd
  • Hi Bernd,
    this is odd.
    Could you send us a small sample project (e.g. count loop in main())
    this issue is reproducible with?
  • Hello Fabian,
    if I create a new CCS Project ("File"->"New"->"CCS Project") and select as target the AM3359, then I get in the "Connection" pulldown menu the option to select "Segger J-Link Emulator". If selecting as target the AM4378, the possiblity to select the "Segger J-Link Emulator" disappears...
    Maybe it would be fastest to show you the effect by a TeamViewer, or Teams meeting?
    Bernd
  • Hi Bernd,
    we are able to reproduce this issue.
    Could you please unzip the content of the following file (contains an xml-file)
    - download.segger.com/Fabian/211109_jlinkcortex_a9.zip
    to the following directory of the CCS installation
    - %CCSInstallDir%\ccs\ccs_base\common\targetdb\drivers
    and try again?
    On our side this solves the issue.
  • Hello Fabian,
    it works now - I could connect, download and run a test program. Thanks!
    However, for your information, I get a few messages in the Console:
    CortexA9: Trouble Reading Register REG_SYSTEM_MMU_CONFIG: No mapped register was found for 1929379842
    CortexA9: Trouble Reading Register REG_SYSTEM_TARGET_CONFIG: No mapped register was found for 1929379840
    CortexA9: Trouble Reading Register REG_SYSTEM_MMU_STATUS: No mapped register was found for 1929379843
    CortexA9: Trouble Reading Register CP15_Registers.REG_CTXA9_CP15_C2_TTBCR: No mapped register was found for 655294978
    CortexA9: Trouble Reading Register CP15_Registers.REG_CTXA9_CP15_C2_TTBR0: No mapped register was found for 655294976
    CortexA9: Trouble Reading Register CP15_Registers.REG_CTXA9_CP15_C2_TTBR1: No mapped register was found for 655294977
    CortexA9: Trouble Reading Register CP15_Registers.REG_CTXA9_CP15_C3_DACR: No mapped register was found for 655295232
    Bernd
