[SOLVED] J-Link V7.52 Firmware Restoration
  • [SOLVED] J-Link V7.52 Firmware Restoration
    I just installed J-Link 7.52. Unfortunately I let the installer change the Keil toolchain , too.
    When trying to connect to the target only the automatic firmware restoration starts, again and again.
    The J-Link stays in bootloader mode, even after USB-reconnection (see attached screeshot).
    Could you provide your J-Links serial number for reference?
  • Hi Detlef,
    Thank you for clarifying.
    Indeed there seems to be an issue with J-Link Ultra/Pro V4.3 and the last update.
    We are currently working on a fix and a patched release is planned later today.
    To get an automatic notification when the release is available you can subscribe here:
    segger.com/notification/subscribe.php?prodid=7
    Should the FW update from the new release not fix this issue could you open a support ticket as explained in my signature?
    As a general reminder, please note that the probe you are using is out of support for more than 6 years now.
    Should you plan on renewing the support you would need to get a new probe. For this our trade in program can be used:
    segger.com/purchase/trade-in-program/
  • Hi Nino,
    after reconnecting the JLink I started JLink_V670g. It comes up with "J-Link V6.70g Firmware Restoration ".
    The firmware update closes successfully but J-Link communication fails with timeout :
    "Requested 4 bytes, received 0 bytes !"
    The J-Link stays in bootloader mode.
    Detlef
  • Hi Detlef,
    Why would you use an older J-Link version when the one with the fix is already released?
    Could you try the following?
    - Power cycle the J-Link.
    - Open J-Link Commander from the V7.52a release
    - Accept the FW update
    Does the J-Link function now?
  • Hello Detlef,
    This thread will be marked as solved now.
    Happy debugging!
