[SOLVED] SEGGER RTTLogger in Background
  • [SOLVED] SEGGER RTTLogger in Background
    Hello all,
    we have the problem, that we can't use the RTT Logger in the background. We want to test on a Jenkins and at the same time we want to log the RTT output. On Jenkins we are only able to use one Terminal at the same Time, so we have to start the Logger and put it into the Background till the tests are finished. When we start the Logger normally everything works fine, but when we try to put it into the Background by using the “&” attribute, the Logger isn't able to find the RTT Block and is shutting down.When you open the ongoing processes with htop or similar there is still a process from SEGGER RTTLogger after killing this process the logger doesn't generate an output file. Is there a possibility to set the Logger in the background and get the log when killing the process?
    Tom
    The RTT Logger was not designed for such a purpose.
    It is designed to be used with direct user interaction.
    We would highly recommend to acquire the J-Link SDK and either to
    a) adjust the RTT Logger to fit your needs (the SDK comes with the RTT Logger source code) or
    b) create your own application using the SDK to control the J-Link and RTT directly.
    For further information about the J-Link SDK please refer to:
