[SOLVED] how to use pcrop of stm32f7xx in segger embedded studio
  • [SOLVED] how to use pcrop of stm32f7xx in segger embedded studio
    how to use the pcrop of stm32f7xx in segger embeded studio, I found a pdf "dm00346619",I saw the usage process, but I don't know how to use it in segger embedded studio, how to generate the symbol file and use it in segger embedded studio?
    As this is a chip feature simply write to the corresponding registers as documented in the St documentation.
    You can do so either directly by accessing the registers via pointers in your application or you can also use the CMSIS Files provided with the STM32F7xx CPU Support Package.
    segger.com/products/developmen…o/technology/cpu-support/
    That way you can use the CMSIS macros which can make things easier. Just make sure to include the right device header in your application.
    Everything else should be documented in the ST manuals.
