I am using a BLDC_SHIELD_TLE9879 from Infineon to drive brushless motors for my masters project and I am having trouble connecting to the TLE9879 chip on the shield via a 10 pin J-Link connection in Arm Keil (TDO always high).
The debugger I am using is the J-Link EDU Mini.
Infineon shield: infineon.com/cms/en/product/ev…oards/bldc_shield_tle9879
EDU Mini: segger.com/products/debug-prob…k/models/j-link-edu-mini/
I believe the issue is due to the fact that the J-Link EDU Mini is designed for 3.3 V targets, while the infineon shield I am trying to connect to works on 5 V (with a minimum threshold of 3.7 V to detect a digital high).
I attempted to solve this issue using a custom connector I made allowing for level shifting from 3.3 V to 5 V for the appropriate signals between the J-Link EDU Mini and the infineon shield. However, the shield was still unable to connect to the debugger.
Assuming I did the level shifting correctly, can this approach work? If so, I can then assume that I did not correctly set up my level shifting.
Another possible solution would be for me to purchase the J-Link EDU Debug Probe, which seems to have target voltage ratings between 1.2 V and 5 V. However, this debugger appears to only have a 20 pin connector. Would I then need the appropriate adapter?
EDU Debug Probe: segger.com/products/debug-probes/j-link/models/j-link-edu/
MarkC
MarkC
