[SOLVED] Read Chip ID register and Save Chip ID into Text File?
  • [SOLVED] Read Chip ID register and Save Chip ID into Text File?
    I have create a jlink command file to read out the MCU chip ID as below:
    mem32 0x40020004 1
    mem32 0x40020008 1
    I use the window batch file to run the above jlink command file:
    JLink.exe -device AMA3B1KK-KBR -if SWD -speed 100 -autoconnect 1 -CommanderScript JLinkCommandFile.jlink
    The chip ID able to show on the command prompt correctly,
    my questions --> is there anyway to save the Chip ID into a text file?
  • You can do it like this:
    JLink.exe -device AMA3B1KK-KBR -if SWD -speed 100 -autoconnect 1 -CommanderScript JLinkCommandFile.jlink > MyOutFile.txt
    Note that the output format of J-Link Commander may change in a new version without prior notice or release note entry.
    It is a test utility and not designed for customized automation.
    We recommend the J-Link SDK for such setups.
