[SOLVED] Having trouble applying a patch for integrating SystemView to trace RTOS
  • [SOLVED] Having trouble applying a patch for integrating SystemView to trace RTOS
    I'm following this wiki to integrate SystemView into my application for tracing RTOS.
    I put the patch file inside freertos/source directory, and running the patch command results in the following:
    patch -p1 -r . < FreeRTOS_10_4_3.patch
    can't find file to patch at input line 4
    Perhaps you used the wrong -p or --strip option?
    The text leading up to this was:
    |diff -rupN org/config/FreeRTOSConfig.h new/config/FreeRTOSConfig.h
    |--- org/config/FreeRTOSConfig.h 2020-12-15 19:53:08.000000000 +0100
    |+++ new/config/FreeRTOSConfig.h 2021-03-10 13:28:14.645130255 +0100
    Also to confirm, the SystemView source files being referred to in the Wiki page include SEGGER_SYSVIEW_FreeRTOS.h & SEGGER_SYSVIEW_FreeRTOS.c, yes?
    Most likely the patch file does not fit the folder structure used in your project. In that case we recommend to patch manually without a patching tool.
    There are not that many changes necessary.
    Yes.
    See the example project for reference.
