[SOLVED] Ozone 3.24b compatibility with JLink remote server
  • [SOLVED] Ozone 3.24b compatibility with JLink remote server
    How to know which version of JLink remote server is compatible with Ozone?
    I'm using Ozone 3.24b.
    The Ozone release notes say the version 3.24 now uses J-Link library 7.22a, but now there is a 7.22b and 7.25. So how to know which one to use?
    I have 3 remote PCs and 7 J-Links. The remote PCs are currently running Jlink software 7.20.
    If I move to Ozone 3.24b does it mean I need to update all 3 PCs to newer JLink software?
    Does it also mean I need to update the firmware on all 7 of my J-Link Pro?
    When I connected Ozone 3.24b to a J-Link Pro v5.0 it did not try to update the firmware from Apr 27 version. But when I tried to connect Ozone 3.24b to a J-Link 4 with Apr 27 firmware, it tried to update it, but somehow failed and now it is in bootloader mode. So now I need to go to the lab (I work remote) to unplug the JLink Pro and recover it.
    Would be nice if I could use newer version of Ozone (requires changing central linux server only 1 time) and keep using existing version of J-Link software on Windows PC, otherwise I have to update 3 Windows PCs and 7 J-Links every time I change Ozone version.
    So I would like some guidance on Ozone compatibility with remote J-Link server on Windows and firmware on J-Link pro v4 and v5.
    Generally we recommend to keep the versions in sync when possible.
    However we always try to keep things backwards compatible so a new Client version should always work with an older J-Link DLL.
    It also works the other way around if no new major features have been added to the server (see release notes).
    As explained above this should work without any issues as Ozone is the client side.
    That issue is not known to us.
    Should it be reproducible feel free to open a J-Link support ticket as explained in my signature.
