[SOLVED] Remotely control Ozone
  • [SOLVED] Remotely control Ozone
    Hi!
    I tried searching around but could not find anything related to this.
    Is there a way to be able to remotely control Ozone from an external application, for example a python script?
    Thanks!
    Best Regards,
    Tze Wey
    Yes you can start Ozone via command line. So you can use it e.g. within your Python script.
    To automate the Ozone GUI actions Ozone has its own scripting which is done in the Ozone project file directly.
    Both is described in the Ozone user manual.
    An example on Ozone automation can be found here:
    wiki.segger.com/Automated_Tests_with_Ozone
