[ABANDONED] Error while determining flash info on SAMV71
  • [ABANDONED] Error while determining flash info on SAMV71
    I'm experiencing this on a ATSAMV71Q21B. I've erased the chip completely using different methods and tried the following commands:
    1. h
    2. rx 300
    3. erase
    The last part fails with error -1, failed while determining flash info, claiming it failed to prepare RAMCode.
    Full log:
    1. Target connection not established yet but required for command.
    2. Please specify device / core. <Default>: ATSAMV71Q21
    3. Type '?' for selection dialog
    4. Device>connect
    5. Please specify target interface:
    6. J) JTAG (Default)
    7. S) SWD
    8. F) FINE
    9. I) ICSP
    10. C) C2
    11. T) cJTAG
    12. TIF>s
    13. Specify target interface speed [kHz]. <Default>: 4000 kHz
    14. Speed>auto
    15. Device "ATSAMV71Q21" selected.
    16. Connecting to target via SWD
    17. Found SW-DP with ID 0x0BD11477
    18. DPIDR: 0x0BD11477
    19. Scanning AP map to find all available APs
    20. AP[1]: Stopped AP scan as end of AP map has been reached
    21. AP[0]: AHB-AP (IDR: 0x04770041)
    22. Iterating through AP map to find AHB-AP to use
    23. AP[0]: Core found
    24. AP[0]: AHB-AP ROM base: 0xE00FD000
    25. CPUID register: 0x411FC271. Implementer code: 0x41 (ARM)
    26. Found Cortex-M7 r1p1, Little endian.
    27. FPUnit: 8 code (BP) slots and 0 literal slots
    28. CoreSight components:
    29. ROMTbl[0] @ E00FD000
    30. ROMTbl[0][0]: E00FE000, CID: B105100D, PID: 000BB4C8 ROM Table
    31. ROMTbl[1] @ E00FE000
    32. ROMTbl[1][0]: E00FF000, CID: B105100D, PID: 000BB4C7 ROM Table
    33. ROMTbl[2] @ E00FF000
    34. ROMTbl[2][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    35. ROMTbl[2][1]: E0001000, CID: B105E00D, PID: 000BB002 DWT
    36. ROMTbl[2][2]: E0002000, CID: B105E00D, PID: 000BB00E FPB-M7
    37. ROMTbl[2][3]: E0000000, CID: B105E00D, PID: 000BB001 ITM
    38. ROMTbl[1][1]: E0041000, CID: B105900D, PID: 001BB975 ETM-M7
    39. ROMTbl[0][1]: E0040000, CID: B105900D, PID: 000BB9A9 TPIU-M7
    40. Cache: Separate I- and D-cache.
    41. I-Cache L1: 16 KiB, 256 Sets, 32 Bytes/Line, 2-Way
    42. D-Cache L1: 16 KiB, 128 Sets, 32 Bytes/Line, 4-Way
    43. Cortex-M7 identified.
    44. PC = FFFFFFFE, CycleCnt = B5F633CE
    45. R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    46. R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    47. R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    48. R12= 00000000
    49. SP(R13)= FFFFFFD8, MSP= FFFFFFD8, PSP= 00000000, R14(LR) = FFFFFFF9
    50. XPSR = 01000003: APSR = nzcvq, EPSR = 01000000, IPSR = 003 (HardFault)
    51. CFBP = 00000000, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00
    52. FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000
    53. FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000
    54. FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000
    55. FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= FFFFFFFF
    56. FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000
    57. FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000
    58. FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000
    59. FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= FFFFFFFF
    60. FPSCR= 00000000
    61. J-Link>rx 300
    62. Reset delay: 300 ms
    63. Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
    64. Reset: Halt core after reset via DEMCR.VC_CORERESET.
    65. Reset: Reset device via AIRCR.SYSRESETREQ.
    66. J-Link>erase
    67. Without any give address range, Erase Chip will be executed
    68. Erasing device...
    69. J-Link: Flash download: Total time needed: 7.744s (Prepare: 0.038s, Compare: 0.000s, Erase: 7.700s, Program: 0.000s, Verify: 0.000s, Restore: 0.005s)
    70. ****** Error: Failed to prepare RAMCode using RAM
    71. Error while determining flash info (Bank @ 0x80000000)
    72. ERROR: Erase returned with error code -1.
    73. J-Link>
    I've used 7.00a and 7.22a.
    1. SEGGER J-Link Commander V7.22a (Compiled Jun 9 2021 16:38:16)
    2. DLL version V7.22a, compiled Jun 9 2021 16:38:00
    3. Connecting to J-Link via USB...O.K.
    4. Firmware: J-Trace PRO V1 Cortex-M compiled Feb 2 2021 16:38:18
    5. Hardware version: V1.00
    6. S/N: 751000526
    7. License(s): RDI, FlashBP, FlashDL, JFlash, GDB
    8. IP-Addr: 192.168.0.6
    9. Emulator has RAWTRACE capability
    10. VTref=3.219V
    11. Type "connect" to establish a target connection, '?' for help
    12. J-Link>
    The post was edited 1 time, last by emrainey: fixing code/logs ().
  • This morning I tried something different, by using the erase as a range.
    1. J-Link>erase 0x400000 0x600000
    2. Erasing selected range...
    3. J-Link: Flash download: Total time needed: 7.744s (Prepare: 0.081s, Compare: 0.000s, Erase: 7.659s, Program: 0.000s, Verify: 0.000s, Restore: 0.004s)
    4. J-Link: Flash download:
    5. Flash sectors within Range [0x00400000 - 0x00600000] deleted.
    6. Erasing done.
    This seemed to work correctly.
    What is the difference in the SEGGER tools between erase (ERASE chip?) and erase 0x400000 0x600000 ?
  • Since Admins aren't answering these messages, I'll just chime in that that range in the error above is for the QSPI memory, which isn't attached or enabled (AFAIK). Perhaps this RAMCode which is loaded to clear the flash thinks it has to erase a QSPI memory as well? How do we stop it from doing that?
    this is not a support forum. If you are entitled to support please use our official support channel as explained in my signature.
