[SOLVED] Ozone installation problem on Kubuntu
  • [SOLVED] Ozone installation problem on Kubuntu
    Hi All,
    in the past I often needed to use a Linux Laptop for Ozone/J-Link, mostly with Linux Mint.
    Ozone and J-Link always installed without problems.
    Due to other circumstances I now had to install a current Kubuntu (21.04) on a new Laptop.
    With this install a have problems installing Ozone.
    J-Link installed fine, but when I try to install Ozone from Ozone_Linux_V322e_x86_64.deb I get the following error message (also shown in the screenshot).
    Error: Cannot satisfy dependencies
    Does anyone has an idea?
    Martin
  • Hello Martin,
    Such an issue is not known to us. Kubuntu is not one of the tested distributions by us, but it should still work as well as with Ubuntu.
    Anyhow I will try to get a hold of an Kubuntu VM and see if the issue is reproducible.
    In the meantime could you give the portable tarball of Ozone a try?
    segger.com/downloads/jlink/Ozone_Linux_x86_64.tgz
    Does this work on your setup?
  • Hello Nino,
    thanks for the quick response. The tarball works out of the box!
    I didn't do extensive tests, but Ozone does flashing, debugging, single stepping, etc. just fine.
    So I think we have a winner and I am up running, thanks for the help.
    Can I give you any other usefull information to investigate the issue?
    I thought that all ubuntu flavours are very much the same under the hood.
    Sadly the qApt Package Installer doesn't show which dependency causes the problem.
    Martin
  • Hello Martin,
    The issue is indeed reproducible.
    We will check if this is something that can be fixed from our side.
  • Hi Martin,
    Yes we were able to fix the issue.
    Great to hear that it is working for you.
