We have designed hardware with the renesas RZ /A1H microcontroller.
We use two SPI Flash units similar to the units used in the renesas RSK demoboard but with lower memory size:
- RSK demoboard : Cypress S25FL512S 64Mbytes
- our HW: S25FL128S 16Mbytes.
The first Flash spi uses the ports indicated in the RZ manual (the same as the RSK demoboard) while the second uses different ports.
We can download the bootloader but not the code of our program.
Could it be a problem of incompatible flashes?
I read in the forum that the segger uses fixed ports for the second flash (same as RSK renesas): is it true?
if yes is it possible to change this setting?
Robert
Robert
