[ABANDONED] Segger inttypes.h incorrectly defines SCNu8, error detected by code analysis
  • [ABANDONED] Segger inttypes.h incorrectly defines SCNu8, error detected by code analysis
    The header file inttypes.h provided by Segger Embedded Studios does not correctly define SCNu8. The macro SCNu8 should be the vscanf formatter to read an uint8_t type. According to multiple sources online it is properly defined as:
    #define SCNu8 'hhu'
    decimal scanf format for uint8_t
    However in SES inttypes.h it is defined:
    // %u
    #define SCNu8 "u"
    #define SCNu16 __RAL_SCN_16_PREFIX "u"
    #define SCNu32 __RAL_SCN_32_PREFIX "u"
    #define SCNu64 "llu"
    This results in the static analysis tool generating an warning:
    format specifies type 'unsigned int *' but the argument has type 'uint8_t *' (aka 'unsigned char *') [clang-diagnostic-format]
    when the code has
    uint8_t log_severity_lvl;
    sscanf( argv[1], "%"SCNu8, &log_severity_lvl ) );
    Could you clarify which version of Embedded Studio you are using. What toolchain? Which run time library?
