[SOLVED] Editor: font with ligatures feature
  • [SOLVED] Editor: font with ligatures feature
    I find beatiful font with ligatures feature: FiraCode.
    I set this font as default for editor, But I'm not sure if the editor supports the function of replacing some characters.
    Searching the forum showed that the option is there (one, another (search result: span.s1 {font-variant-ligatures: no-common-ligatures})) , but can I use it?
    In notepad++ for support ligatures enough enabling DirectWrite, maybe You have this options too?
    best regards,
    Max
  • Hello Max,
    Currently there are no ligature fonts available for ES and external fonts can't be added.
    There are also no plans to add other fonts right now.
    You can find the available preinstalled fonts for ES under Tools->Options->TextEditor.
    The two threads you linked have nothing to do with font ligatures in ES. It is rather a broken quote formatting from the Forums Text Editor where the post creator did not know how to use quotes in a thread properly.
