Can't run Segger SystemView
    • Can't run Segger SystemView
      I used segger systemview about 5 months ago and now I want to use it again. I installed it, when I run the application the license window appears. After clicking the "continue" button in the license window, the system information screen appears. Clicking the "Ok" button on this screen, the screen disappears. Segger SystemView seems to be running but I cannot see the window it is running. You can see the situation I live in from the image below. What can I do about this problem?
      I've tried reinstalling 5-10 times and also tried different versions, but the result is the same.
      The post was edited 2 times, last by kemaalyilmaz ().
      Could you give the latest SystemView and J-Link software version a try?
      Do you still see the issue then?
    • I am using st-linkv2.1 by converting it to j-link using the st-link reflash utility. I will try reinstalling the st-link reflash utility. I'll let you know if the problem is fixed. If you have any other suggestions, I'd love to hear.
      it should make no difference what J-Link you are using.
