[SOLVED] Save dialog when exiting J-Flash
  • [SOLVED] Save dialog when exiting J-Flash
    Is there a setting or command line option to hide the save dialog when exiting J-Flash?
    I omit the path name of CurrentFile of the J-Flash configuration file so that the SREC file in the same folder as the J-Flash configuration file will be read when J-Flash is started by double-clicking the J-Flash configuration file, and it works as expected.
    However, because of that, whenever I try to quit J-Flash, I get tired of seeing the dialog.
    The dialog says "The J-Flash project has been modified. Do You want to save your chainges?".
    Heck no. It was J-Flash that changed the relative path to the absolute path without permission. I haven't changed anything, and I don't want it to change.
    Currently, there is no way to prevent this from happening.
    I will raise this as a topic on our next internal meeting and come back to you
    as soon as I have news regarding this.
  • I just ran into this too, very annoying. But I did discover a couple of work-arounds.
    1) If the file is in the same directory as the config file, you can edit the config file and specify the filename as c:MyFile.bin (Windows speak for this drive, current directory). That doesn't work as well if you are working on a local drive then want to move to a share drive for production department (as I am doing), but change the drive letter in the file and all is good.
    2) Use the command-line and specify the data file name there, this is what I am doing instead. Just put this command in a batch file and all is automated and no worries about file name in the config file (the no space after -openproj and -open is a bit difficult to read, but it works):
    "C:\Program Files (x86)\SEGGER\JLink_V720b\JFlash.exe" -openprjMyProj.jflash -openMyFile.bin -auto -exit
    We added this internally.
    For future releases, a relative path in a project file will not be detected as a project file change anymore after loading the project.
    Stay up-to-date regarding J-Link:
    segger.com/notification/subscribe.php?prodid=7,94
