I've run into something curious with v10.x J-Links. I have a project using the STM32F103ZG microcontroller and I'm currently using IAR EWARM 9.1.
Flashing and debugging with older J-Links (v8, v9.1 and Ultra v4.3) work just fine in either JTAG or SWD mode - JTAG has been the default since the beginning. However, when some people started using v10.0 or v10.1 J-Link, flash and debug would only work in SWD mode.
As an example, here's the Debug log from when I try to "Debug without download" using a v10.1 J-Link with JTAG configured instead of SWD. The J-Link's LED quickly flashes red/yellow (or red/green?) and I get a message "Failed to get CPU status after 4 retries".
This isn't a problem in the sense that simply changing to SWD works. But it was unexpected and there are some worries that maybe the JTAG isn't correct on the schematic/PCB layout (I'm not an EE so I can't begin to guess what's going on there - if anything). This happens with both a v10.0 and v10.1 J-Link. All older J-Links I've tried work fine in JTAG mode (and SWD mode).
For comparison, I have also attached a debug log of a J-Link Ultra+ v4.3 successfully using JTAG mode.
I'm wondering if this is something we should be concerned about, and if so do you have any suggestions for where we should look?
- Tue May 04, 2021 07:58:28: IAR Embedded Workbench 9.10.1 (C:\Program Files\IAR Systems\Embedded Workbench 9.0\arm\bin\armPROC.dll)
- Tue May 04, 2021 07:58:28: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 9.0\arm\config\debugger\ST\STM32F1xx.dmac
- Tue May 04, 2021 07:58:28: JLINK command: ProjectFile = C:\devtrees\obfuscated\settings\obfuscated_Debug.jlink, return = 0
- Tue May 04, 2021 07:58:28: Device "STM32F103ZG" selected.
- Tue May 04, 2021 07:58:28: DLL version: V6.94d, compiled Feb 12 2021 15:56:38
- Tue May 04, 2021 07:58:28: Firmware: J-Link V10 compiled Apr 27 2021 16:35:48
- Tue May 04, 2021 07:58:28: JTAG speed is initially set to: 32 kHz
- Tue May 04, 2021 07:58:28: TotalIRLen = 9, IRPrint = 0x0011
- Tue May 04, 2021 07:58:28: STM32 (connect): Can not attach to CPU. Trying connect under reset.
- Tue May 04, 2021 07:58:28: Warning: STM32: Connecting to CPU via connect under reset failed.
- Tue May 04, 2021 07:58:28: Hardware reset with strategy 0 was performed
- Tue May 04, 2021 07:58:28: Initial reset was performed
- Tue May 04, 2021 07:58:29: Warning: STM32: Connecting to CPU via connect under reset failed.
- Tue May 04, 2021 07:58:29: TotalIRLen = 9, IRPrint = 0x0011
- Tue May 04, 2021 07:58:29: STM32 (connect): Can not attach to CPU. Trying connect under reset.
- Tue May 04, 2021 07:58:30: TotalIRLen = 9, IRPrint = 0x0011
- Tue May 04, 2021 07:58:30: STM32 (connect): Can not attach to CPU. Trying connect under reset.
- Tue May 04, 2021 07:58:30: Warning: STM32: Connecting to CPU via connect under reset failed.
- Tue May 04, 2021 07:58:31: TotalIRLen = 9, IRPrint = 0x0011
- Tue May 04, 2021 07:58:31: STM32 (connect): Can not attach to CPU. Trying connect under reset.
- Tue May 04, 2021 07:58:31: Warning: STM32: Connecting to CPU via connect under reset failed.
- Tue May 04, 2021 07:58:32: TotalIRLen = 9, IRPrint = 0x0011
- Tue May 04, 2021 07:58:32: Warning: STM32: Connecting to CPU via connect under reset failed.
- Tue May 04, 2021 07:58:32: STM32 (connect): Can not attach to CPU. Trying connect under reset.
- Tue May 04, 2021 08:00:47: Unloaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 9.0\arm\config\debugger\ST\STM32F1xx.dmac
- Tue May 04, 2021 08:00:47: IAR Embedded Workbench 9.10.1 (C:\Program Files\IAR Systems\Embedded Workbench 9.0\arm\bin\armPROC.dll)
- Tue May 04, 2021 08:00:47: Loading the jlink driver
